What Primer?
Hey all.
Weather permitting, ill be spraying the interior of the olop satin black at the weekend. What primer should i use? was gonna go straight on with the grey, would this be all right, remembering theres no carpit in there til hes on the road.
cheers for the help ;)
Ben
  • Replies 8
  • Views 1.6k
if its sound orig paint then key it with a red scotch pad and straight on with the top coat....any bare metal spray with etch primer
wicked, cheers mate :D
PASTIC NEEDS AN ADHESION PROMOTER this ensures the primer adheres to the pastic, or your paint will be coming off.. hope this helps
yeah right about plastics
i assumed you meant the floor and metalwork?
yea i do. only plastic in there atm is a dash and steering wheel ;)
right cool
give it wipe over with white spirit before you spray....prob got a build up of grime n silicone over the years
cheers buddy, one las question, where I've removed the rear seats, i have wholes in the floor, will they be ok or should i fill/weld them?
cars being caged and fake floored at some point.
i think id put the bolts back into threaded holes and use a rubber grommet on any others
welding will make a mess....i guess a dollop of seam sealer would sort any small ones
