How can I make my MK1 more Economical
How?
Its a 1093cc 4-Speed and it sucks juice like no other, I get about 170 miles to 25 quid. The 1272cc CL engine I had in whats now my G40 got 400 miles to 30 quid!
I thought about these
- Electronic Ignition
- GT 5-Speed Gearbox
- Service it
- Don't rag it
What do you guys reckon, this car is raping my wallet for fuel but I don't wanna sell it cause its a sweet motor.
How hard would it be to wire in my old CL block?
Help!
Cheers,
Jimmy B
  • Replies 24
  • Views 2.2k
That's 30mpg, so seems a bit low. If it's being driven around town all the time, that wouldn't be too far out, particularly if it's being driven hard. Servicing will help a lot.
It gets full throttle and driven round town, so yeah... lol
I've heard that gingerness increases fuel consumption...... :lol:
Same MPG that mine gets :(
how long has your cl had the g40 in it must be at least 2 years and the price of fuel has changed loads
luke
Edited by ahh claudia
over 3 years now Luke, long time. even so I think that a 1272 SPI lump would be way more economical, I'd do it but I ain't got a clue about wiring lol
I think I might do the Gearbox, electronic ignition, service and drive a bit easier for now, maybe I'll tackle the engine conversion next spring, anyone wanna help, it'll be a right laugh!
leccy ign is deffo a good idea
make sure all service parts are new/recent ....have the c/o set up
chose a oil thats not too heavy for the engine...the handbook should have a few to chose from
make sure the tyres are pumped up
try and push the car on flat ground to make sure the brakes arnet binding
I do service it regular although its about due again now, need to do an oil change and get some 15/40w in there again.
C/O set up? How do I do that?
Thanks,
Jimmy
i assume its a carb'd mk2 if it still has points?
get a mot station to put the gas tester up the exh and ajust the carb to 1.5% ish
Edited by steveo3002
Adjust the idle mixture screw as this will effect the economy a fair amount if its chucking to much fuel down
And advance the ignition timing, does that mk1 engine have some weird vacuum retard system on it?
Engine pics would be cool just so i could have a lookee
Ok, I'll get some piccys up over the weekend so you boys can have a goose at it and gimme the score on what the crack is etc, etc.
lol
How?
Jimmy B
I dream of those figures!!! :) in my 328 i get 280miles to 60 quid!!!! But that is all town driving.
I would have though the 5 speed box would help. esp on motorway journeys.
Mark
According to one eBay vendor attach a magnet to the fuel line with a cable tie!
But I'd say, get it serviced and tuned or do it yourself.
I found a Gunson carbtune (let's you see inside the cylinder to observe the flame colour) great for achieving perfect idle
on my carb car.
Weather's getting colder.
Check autochoke or ensure manual choke is pushed in earlier, and consider warm air feed to both air inlet pipes (people used to shield half the radiator to speed up car warming as engines are inefficient while warming up). Shed weight from the car any safe way you can including not carrying a full tank of fuel, replacing spare wheel with tyreweld spraycan, carry minimal tools, and ensure the tyres are hard, then drive as sedately as you can bear, turning off the engine (once warmed up and not at front of a queue and not going to freeze to death) if you will most likely be still for more than 15 seconds. I did this for a week and managed 4% improvement to my mpg, but probably -5% for all the other cars that overtook me exiting villages, or braked hard as they caught me up coasting to a roundabout.
Search for 'eco driving' It'll be part of new driving tests!
http://www.energysavingtrust.org.uk/what_c...ficient_driving
what about putting the fuel injection system off a 1 litre mk3 engine onto the existing engine? I remember Gaz doing something similar with an old mk2 he had once. Maybe he can give you some pointers? Although it's probably not going to be much less work than swapping the whole engine over.
jimmyB
i had the same thing on the derby, just g40 it, it will still be far more economical!
jimmyB
I know, its cheaper to run my G than it is the MK1.
get you are carb set up and timming done my be slightly out
push it :ninja:
Leccy ignition is a good idea. Use parts from an '86 on Mk.2 Polo(coil, amp and wiring) and a dizzy from a mid 80's Saab.
Ragging those old Solex carb'd engines is always a recipe for poor fuel consumption. MOT stations just set the CO to pass emissions tests and rarely set them up to pass emissions and drive nicely. When driven with some degree of mechanical sympathy, they can be quite good on fuel.
Don't bother using anything lighter than 15/40 engine oil on the old mechanical head engines as it'll gain you nothing and their not overly keen on the stuff either.
Nice one, cheers Steve!
What gearbox shall I put on her? Would an 8P work ok?
Thanks,
Jimmy
Steve do I need the dizzy from a Saab 900 or something, will that fit on?
A lot of this seems like a lot of time and effort for a problem which almost entirely down to your right foot ;)
Autocar suggest that 30mpg is what to expect with 'hard driving' in 'difficult conditions’. On that premise, your car is drinking as expected. Similarly, driving at a constant 70mph also gives 30mpg.
Try driving more progressively and stick to 60 not 70+ on motorways and you should at least get 35-37mpg. I also agree that checking ignition and carb settings can never be a bad thing, as in this fuel injected time we're in, people just simply forget.
Shed weight from the car any safe way you can including not carrying a full tank of fuel, replacing spare wheel with tyreweld spraycan, carry minimal tools, and ensure the tyres are hard.
No offence but I wouldn't bother doing any of that. Less weight and over inflated tyres would make for some pretty lethal handling. Yes, cut down on unnecessary weight and keep tyres up to their recommended pressure, but don't over-do it.
Cheers Dan,
I just filled up today and I've not hammered it and the fuel consumption seems better already!
I think that a 5-speed box, Saab dizzy, electronic ignition and a service will only help the situation!
Cheers,
Jimmy
