Lock help
Hi all.
First off my car is a 1.4cl 1997 vw polo.
I have dissconnected the central locking until I fix the lock so that it works manually.
A couple of weeks ago my key got jammed in the door and didn't want to turn. After a while and with some force i managed to get the key out.
I took the lock to VW and they told me which parts had broken and I bought the replacement parts. I went to fix the parts and the whole barrel fell out, which made all the little gates fall out. One of the springs that the gates push against is all bent and broken.
I'm wondering...do I need to go to vw and get a whole new lock and new key? How much will this cost?
Or
Can I go down breakers and take a handle with a lock and get a lock-smith to fiddle with the lock so that i can use me orignal key?
Thanks in advance!
Edited by lewin
  • Views 1.2k
iv done a very simerler thing on mine. lol
snapped something or other in the locking mech, now i have to lock it from the left hand side. . its fucking annoying
so also interested
i think go to the breakers thats your best bet, and alot cheaper than going to VW and getting a new key aswell.
try getting them to give you a barrel with the key and put it in your exsiting lock if you can.
I'm going to need a whole new lock, which means a new key.
Don't really wanna have 2 keys! But haven't got the option really.
I certainly know you can "re-tumble" the gates on older locks (mk2 golf, mk2/3 polo etc...) but they have more traditional shaped keys. In any case it really needs to be done by a locksmith. It's possible to DIY but a mate of mine did it once on his mk2 golf and you could open the door with pretty much any key that'd fit in the lock afterwards!
Personally, I'd get a lock from a scrapyard and try to get it retumbled to suit your existing key. Perhaps take your key into some local locksmith places first and check they can do that type of key.
I no longer need a new lock! VW have given me some springs to replace the broken ones.
The only problem I got is putting the gates back in the right sequence!
Get a rear door handle(delocked) on the passenger side & use the passenger one on the drivers side.
