my passanger door wont open :(
ok here is the deal, my mate tryed to close my door but it wouldnt and i realised 2 bolts had fell out the door at the door latch, i replaced these and tightened them solid! and all was well.....or so i thought, after a few times of the door being open and closed it wouldnt open, and the door handel on the interior stays pulled back like you do when u try to open it and if you push it back to normal it just springs bak to open position, i have pulled the door card back and the handel is still attached at both ends and the central locking seames to be working just fine, the door wont open with the handel outside either
WHAT CAN I DO!!! :(
please help me
Which model car??
6n 3door 1.4 16v
bump
i have had the door pannel pulled back and still cant see a problem the interior and exterior handels both still pull the mechacism inside the door but the door wond shift, do you guys know of any way of helping :S
Perhaps pictures may help here...
what do you want pics of?
it is totaly identical to the drivers door but it just wont open fior some reason
