water water
hi guys, ok, here the store, i'we been away in the army for 2 months in a row, and now i come home, there is water in all footwells and under the backseat, and the seats are rotten, and there was actually water drops in the roof to :S bloody fucking water everywhere :S what should i do?
  • Replies 13
  • Views 2k
drill a hole in each footwell, remove all seats and carpet. strip the seats of their covers you should be able to wash then and dry them out. the sponge bits take a while to dry . once the car is dry and youve solved the leak then refit the seats and carpet and dont forget to fill up the holes!
You got a sunroof in the car?
drill a hole? i see how that will fix the problem, but for how long?
i dont have a sunroof :)
Put goldfish in the water and start a craze!!
I thought they may have been the usual water pipe blockage on the sunroof.
Is the battery tray (behind the battery) all in tact? or the rear lights leaking?
you have to fix the reason it is leaking! when my gt was flooded four holes were drilled to let the water out, once it was dry the holes were welded up and undersealed. my guess is water getting in through door seals. i had a polo fox that would leak water if i parked it at a certain angle and the seatbelt would become soaked.
ahh ok :p know what a new door seal cost?
bet theres someone on here stripping a mk3 which has got good door seals for sale.
Have you checked to see if the bung where the bonnet release runs into the engine bay is sealed correctly?
jeah, i fixed the doors with a hole lot af silicone :p have not checked that :D will do now, thanx
take the door card off and make sure the plastic liner is intact, if not you can make another one out of some polythene sheet and use double sided sticky tape, this is what stops the water that runs down the glass from going outside the car and not in! other than that as said battery tray and door rubbers make sure they arn't split. not many other places if you dont have a sunroof.
I know how annoying it is to have a leaky car! especially in winter when the inside of the windows get ice on them!
aha, would that be on top er the bottom of the door?
ohh, plastic liner ass in the carrier bag looking thing that covers the whole door??
Edited by ballemann
Yup, that'll be it. When you remove doorcards, plastic cover that stops you touching window glass.
My old car never had any and it never leaked! Just lucky i guess.
great, done it now, was kind of a bitch to do :S hope that it does the trick :D
anyway i have desided to sell te polo for a golf 1 gti cab :D maybe have the polo just in case, i do love it a bit :p
