are 13's too small for a 6n
I'm looking to get some wellers like this
only thing is they only come in 13'' and i more than likly getting some 80mm colies froma mate cos i cant afford anything lower. so my dilema is would 13''s look ok with a 80mm drop??
cos the car above is gonna be like 120mm
  • Replies 26
  • Views 3.4k
i think they are too small personally. look ok on that car above though.
so is that a no with a 80mm drop then. ??? i will have to go lower to pull this off>?
no idea. just i saw a local lupo round mine with 13's on and it looked poo. needed to go right to the floor which it wasnt. i suppose if you go right down itll look alright?
small wheels are not wrong for the 6n......
Arch gap on the 6n is the problem. Slam it enough and its all good. Plus that car looks pimpo!!
Says me still rocking my stock height!!
My opinion is they look savage above but you couldnt drive the car that low on a daily basis... Well at least round here. It would literally be hopping off the front wishbones... I've 14s and when I go low its a nightmare... 13s would be even worse...
I think 14`s are the smallest size that look good on mk4`s, even then you need to go stupidly low to get rid of the mahoosive arch gap :-(
If you like it though, then go for it 8-)
As I always say. Trying to be the most extreme is pointless unless it looks good.
IE you can get 22s on a Corsa C but it don't look good. You can get 13s on a 6N but don't mean it looks good.
In that example pic the car looks good on 13s, as does that satin black one. Most people keep the car to high and it looks rubbish though!
I'm on 13" 's at the mo, with an 80mm drop. It doesnt look like its riding high though at the moment becuase i have such fooking big tyres on. 175/60/13 i think? If i had some normal tyres on i recon a fair drop would be needed to pull it off, but in the end its up to you i guess! Make it work :D
No.. but to look good u need to get very low to reduce the arch gap and then you are underbelly scrapes on basically everything. A good idea is to run stretched tyres...but slightly chunky/chubby ones thna u would if u had say 14's.
This way u reduce the arch gap without being basically on the floor...wich is fine unless u live near alot of speed bumps
thats my car above lol i use it as a daily i do catch on some stuff but only if u dick about i live near speadbumps n have to go over them alot n its ok ish haha n if u go down vumby roadsu get the ocassional bang n sparks but it nothing to worry about haha :lol:
sorry to hijack the thread but I'm considering to get 13's on mine cause i dont want any rubbage my 15's rub but if i get those wellers will i need to get my arches rolled? or will they be straight fit with no further work required?
i'm not a fan of 13"s on a mk4 but its all about personal taste, if you want to do it then get it done!
I think 13's can look awesome....but its definitely about how you get the stance! only 1 in 10 seem to get it right! And the 1 above defo has it right ;)
13s and a n 80mm drop looks sweet as! i had 13x7 ats classics on my car with 80mm drop i can send you pics if you want mate?
13" minilights??? Major repost but nevermind...
Edited by tomadomeit
yer please. :)
do it.
if it doesnt look low enough I've got an angle grinder :unibrow:
13s look great on mk4s as long as you don't go too low profile on them. 175/60s on a 13x8 look grrrreat.
P.S. nice photo, must have been a skilled photographer ;)
13s look the tits a) as long as the drop is right b) there isnt STUPID balloon sized tyres on there...
do it if you want, but your bum will scrape along on nearly everything, as us mere mortals get scrubbing on 15s not even lowered that lot (manifold, backbox,sump, front arb and splitter) all take a beating at the moment...
personally i dont see the point in buying coilies that only go down to 80mm, might as well save a hundred bob or so and get shocks/springs (80/70) or just save up a bit more for some decent coilies...
shit ones wont be damping adjustable and you might f ind they have too much or too little damping
Start saving for air ride and you will be sorted :lol:
craigs old 1.4 8v pulled off 13's just fine
Was that the purple 1 with full fat interior?
doesnt jason11 have em on his..
i want some of these wheels for winter any one no where to get them from new if i can
need 13x8 or 9's with offset of 0
