MK5 6n2 Passenger Side Indicator
Any one have a near-side indicator for my 6n2? mines a bit scuffed/cracked.
I know GSF and euro do them but second hand is fine with me :) only need the clear plastic bit.
also how difficult is it to remove the old one? (need to take the bumper off etc?)
Ta
  • Views 645
clear ones are an aftermarket accesory and you won't get just the lense,new white one from europart only about £7:00 as i have just bought one......
open the bonnet and next to the headlight where the wing ends you will see a 7mm self tapping screw,take this out and the lamp will slide out from it's hole if you gently tug it.....no bumpers to take off and will take you 5 minutes....
Hi
Are you sure? I have a Mk5 which have crystal clear indicators
u never said it had clears on it,you'll probably have to buy a pair then......still try eurpoart or gsf tho!!
