Pic Reqeust!! (pretty urgent)
as the title says really putting a set of tt seats in my mates car this evening but would like a rough idea of where to start. we have our plan but we'd like to see what you've done! cheers, phil :)
  • Views 1.2k
What time you doin it phil?
dunno yet! stop spamming tim this is important!
if phil (polo01) is online hes the man to ask, his dad made him some nice subframes for his TT seats
Take the runners attatched to the seats.. Place them in the car one at a time...Level them up at correct height using any sort of spacer. Check their fitting (shut Door) Check their straight (Driving Position)
Note - Ensure they are fully back in the runners and put them as far back in the car as you wish them to travel when welded in.
Cut carpet into two parts under front seats and fold it forward outa the way. (If spark gets at this itll go up in seconds so mind it!
Weld a thick steel bar accross sirectly on top of the runners to support the back of seat
Next make up small L Brackets from Thick steel bar
Place the brackets in position and FULLY LEVEL UP SEAT FOR FINAL POSITION
Tack then fully weld up...
A dab of sanding
A dab of primer
A dab of satin black
Refit carpet with thick double sided tape or velcro and cut around the vertical part of L bracket...
Hey presto.... Looks factory and Fully functional..
Dont know what all the fuss is about LOL
Edited by 1stcarsapolo
Oh and heres a quick pic of one of the front mounts so you get the idea... Looks fairly stock in my opinion
HOPE THAT HELPS>>> TOOK ME SOME FIGURING OUT BUT EASY ENOUGH IN HEINSEIT>>>
