Dying the interior?
How do you dye the seats an door cards etc.. in another colour? is there a certain type of spray you have to buy. I've been looking at 'VHT' but I'm unsure.
so to the point.. What do I use? My interior is grey?
  • Views 1.5k
VHT paint? Errrr, isn't that for engines?
Are your doorcards plastic coated like a fox interior for example? If so, you need to find some interior spray the colouryou require (try halfrauds) and follow the instructions on it.
Not sure how good it is as i've never used it. I do little bits like door handles with normal car spray paint, snading back to give the paint something to key onto and then a couple of light coats followed by a coat of lacquer.
i have done it to the doorcards and my seat, works great :D all black interiour, got some vinyl paint, from a shop cald cd-cardic...
VHT do a fabric/vinyl dye that is really good. I have used it on my parcel shelf, and centre console and a few other little bits.
Whoops, i thought he meant VHT as in very high temp paint!
Where can i get some of this stuff from?
Would that shiz be ok on a headlining?
i'd have thought a fabric shop?
they have fabric dye in there.
Edited by scottpolo2001
I sprayed my door cards.. they look ok but one side needs redoing as lacquer fininsh was rubbish!
Bear that in mind guys :D
