what are the largest rims u can put on 2001 polo
just got grey 3dr polo wanted 17 will they fit
  • Replies 23
  • Views 1.4k
Yep, problem will be when you lower it you will probably need your arches flared. Also remove the plastic inner arches.
If you don't lower it you will have a 4x4 Polo.
anything over 16s and lowering will be an issue.
also anything over 16s will look a bit over the top..I used to have 17s on mine but was never that low..
I had at one stage 16" with a 40mm drop and it scrubbed most of the time on the back, turning circles are crap.
Also what engine size is your car? 17's will make 1.4's and below very slow, you will lose a lot of accelaration.
17"+ on a Mk5 just looks stupid, I've only seen one or two exceptions in the past where it looks so-so
Only 17s I'd consider for mine are BBS LMs
:thumbsup:8-) What he said!
go for 22" blings
go for 22" blings
FTW 8-)
go for 22" blings
FTW 8-)
fo' shaw :smoke:
I'm on 17s lowered 50mm =]
why have you posted this topic twice?
Maybe he wanted to add to his post count??
Like what i just did :-p
haha each to their own!
safe for this boys
never knew so many heads would reply
so i wont bother getting 17
just some nice 16 might lower it 30mm
jus bought gti grill and spolier get tints next week
safe
ezi blud sik tingz man dont be getting no 17 y0
too big init
some sik 16 and drop it as far as you like
i seen mandems wid that car rockin 16 and coilovers, wound nearly all da way down no lie man luks sik
safe
too big init
safe
Anyone care to translate that for me :-o
16" BBS RX and coilovers for the win!
Seriously...15's or 16's at a push.
i was down about 70mm on 16s :D
if i put 17's
will they rub
can i still lower bout 35mm
and what tyres do i need lookinf for defo low profiles
but dont want the alloy edge, dont want the tyre to be strecthced
thanks
pmd!
what is THE SCRAPING LIKE ON 17
pmd again lol
put your rims on, and then check with a ruler :)
