strech on a 7j rim
185/50-14 if they are 14's. You do not get Borbet T in 7-15 do you? It gives just a slight stretch, but is still legal
  • Replies 8
  • Views 4.1k
I ran them on my Zender T's (15x7). Bob on.
good day all :-D
lookin to get this kinda strech on a 7j rim for the summer.....any ideas of what tire size i need??
these are waht i want it too look like...but these are 8j
so what tire size would i need to get this on a 7j rim pls :-D
or would that strech look stooopid on a rim that thin?
cheers
taylor
sorry I'm runnin 14x7 modernlines
165/50/15's
You can get 165/55/14s which will do the trick :D
cheers matey :-D
u can lock/delet this now if u want 8-)
Here's a few guidelines from TÜV/tyre manufacturers on suitable wheel/tyre combinations:
175/50-13 Max 6-13
195/45-13 Max 8-13 with minimum 36 psi pressure on 8-13
185/50-14 Max 7-14
195/45-14 Max 8-14
205/45-14 Max 8,5-14
215/40-14 Max 9-14
225/40-14 Max 9-14 (except Toyo's who can be fitted to 10-14)
255/35-14 Max 10,5-14
195/45-15 Max 8-15 (bridgstone B530 is allowed on 8,5-15)
215/40-15 Max 9-15
215/45-15 Max 9-15
215/40-16 Max 9-16
215/35-16 Dunlop max 8,5-16 (used to be allowed on 9-16, but approval has been withdrawn, not sure about Conti)
Club Polo offers the above information for reference only, it is your responsibility to ensure that your wheel/tyre combination is both safe and legal.
andys got 195/45 on an 8 inch rim which is tuv approved so the nearest stretch on a 7 id assume would be the tuv rating of 185/50 would give you the same stretch
ahh balls thats for 14s id assume its the same for 15s tho
Edited by grungeisdead
I'm pretty sure 185/s won't give much on a 7. 165s on a 7 give a similar looking stretch to Andys on an 8.
