ASTONISHING MPG from my 1.4!
Well, last time i filled the car (6n 1.4) up with a full tank i was very disapointed with my 305 miles i acheived.
Sooo this week i have been driving VERY economically, basically how JC did on the Audi A8 episode on top gear.
I have not once gone over 2k rpma and my max speed is not over 50mph. My average rpm is 1,500 lol
Anyway I put in 8 litres of fuel @ 99.9 pence per litre.
So far i have acheived 73miles from this...and ther is still aorund 1 litre left in the tank.
So i calculated that from 7 litres of fuel i got 73miles...wich is 47.41 MPG :)
9.58 PENCE Per Mile
I'm very happy, and i also finally got centre caps for my BBS this morning.
Boner over _____________
Edited by VW_Technik
  • Replies 35
  • Views 2.2k
Wow!
I got 230-240 miles out of £40!! 1.4 8v 6n!!
I get about 300 from a full tank in my 1.6
WOW, i get around 250miles for £20 petrol, mainly motorway tho
Yeah mine is mainly town, stop start driving!
That is really good isn't it..? ^
:D
I dont think many people would like to drive the way i do though..Lets just say the bus infront of me was startign to pull away
Mine is town driving..no motorways, i try not to brake really...i roll up to junctions from afew hundred metres or what eva it may be....i try not to brake for roundabouts and just take them hard n fast, change gear at 2k rpm and cruise at 1.5k rpm lol max speed is 50mph
my max speed is not over 5mph.
How the hell have you driven 73 miles not going over 5mph?
Hmmmmm?!?!?
:lol::lol::lol: ^^^^
Exactly the question i was about to ask.
Edited by StueyB
50 , my keyboard is playing up lol
i regularly get 500miles to a tank in my mk4
Its all about costing and using your toe on the go pedal rather than the foot :)
The "Go Pedal!"
well my 6n is still burning fule like a bitch, even after ireplaced the oxygen sensor !! so iv done 98 miles from a full tank !! hahah
anyone know anything i can do. one of mymates suggested cleaning the throttle body ??
I tend to change gear between 2000 and 2200 rpm when town driving. My car will sit at 40 in 5th at around 1800rpm and can pull quite steadily from there. Anything lower and it labours the engine. I've also mastered the art of coasting.
think I've managed over 300 from a full tank that was a round trip to birmingham and back... and tbo i wasnt exacly driving conservatily and i hit traffic alot!!! so recon i could get more... not bad for a valver :D
god from my 6n 1.6 full tank i get about 220!!!!!
i really need someone to tell me how to sort it!!! i thought lambda or coolant!!
I once managed 45mpg out of the work car (2.5 litre V6). Granted, it was a none-stop mission from Cornwall to Lincoln starting at 8pm and behaving all the way.
Coasting isn't an art, it's bad driving practice. Plus knocking the car out of gear or putting the clutch in early can actually waste more fuel as the car idles.
Small petrol 4 cylinder engines should spend most of their time between 2-3000 RPM, this tends to be where they are most efficient. Lower revs don't always mean better economy, you've go to use the correct gear for the situation.
The merits of economic driving become really apparent when you drive a car with a large capacity engine. The difference between taking it easy and 'nailing it' in the Audi are massive. You can vary average the economy from 30-35 MPG right down to 15 MPG. One of the benefits of a bigger engine with more cylinders is you don't have to rev it hard to make progress...so in some ways it helps economy.
I managed to get 180 miles out of £30 in the GT....
Whereas the 1 litre would do 320+
But I had a dodgy temp sensor and a blow before the lambda sensor in the GT :lol:
Edited by G40_CTM
I got anywhere between 20 and 50 mpg in my mk3 polo 1.0
In the Golf I get between 28 and 32 sort of thing haha
I dont think coasting does actually improve MPG. I've done it for a few weeks and noticed no difference anyways. Aparently, it uses up less petrol leaving it in gear.. so I'm told.
Coasting is dangerous and engine braking is pretty useful tbh. Coasting is bad. Don't do it.
There's a reason it's an instant fail in the driving test.
just cut a hole in the bottom of the car and you can do as many miles as you wish with out havin to look at a petrol station again!!!
