Where is PCD messured from?
As title says really, I have a set of wellers which i did not know the PCD on, I have messured them and from the centre of the hole they are 75mm which i think is a bit odd but from the edge it is 95mm which i find more beliveable rather than 75mm.
So could anyone help me out? i am not really into wheels, as long as they fit and they arent bent i dont care about them but would just like to know!
Thanks a lot, Tomm
  • Replies 10
  • Views 1.5k
from the centre of the bolt hole easy on 4 stud as the holes are opposite each other
Rob
ah right thought so, but 75 mm seemed way to small?
what has a 75mm PCD then? 2000 106's ect?
Nothing has a PCD Of 75, (Well not that i know of) Thought smallest was 98 and thats on a Punto,
106's/Saxo's are 108,
Measure opposite holes, not adjacent.
Imagine a circle drawn through the centre of all the holes. It's the diameter of that circle.
edge to edge is the same as middle to middle.
amazing how many people wave a ruler to try and guess where the middle is
straight over my head, ill just weigh them in...
saves me messuring this that and the other. they are dead anyway, thans for some of your help.
took a whitle for me to get what you mean but i see thanks!
This diagram should clear up any inconsistancies in how you measure pcd (pitch circle diameter).
pretty smart diagram and very handy to know your pcds coz if u ever find some mx5 rims or e30 bmw rims they fit early polos before i knew i would have jus walked past them
