dual 4ohm
been looking for a new sub, and found a few, but some say 2 x 4ohm ect, does this mean i need 2positive and 2 negative from my amp? because mines only got 1 channel for a sub.
Ben.
Oh yes, wheres best place to EARTH my amp in my 6n?
  • Replies 14
  • Views 1.4k
Nope, you wire it in parallel mate. That way it'll show the amp 2Ohms, which is the lowest a lot of amplifiers are stable anyway so it's all good :)
Mine is earthed in the wing on the O/S, had no trouble with it. A lot of people use the seat/seatbelt mounts though I think.
Hope that helps,
-Rich
dual 4 ohm means it can be wired either to 2 ohm or 8 ohm all depends what your amp can run at ;)
my amp is
5 CHANNEL 1000w AMPLIFIER (RRP £200)
Thermally Dynamic Heat Sink
Thermally efficient heat sink structure designed to keep components within accepted heat tolerances
Integrated End Caps
Stylish end caps fit seamlessly to protect the heat sink against alien objects and create clean lines for clean installations
Multi-Function System Management Panel
Enables you to easily tailor the characteristics of the signal to your audio preferences
Screw Down Connectors
Efficient screw down connections ensure a secure bond between components in the audio system
Product Specifications
80 Watts RMS x 4 + 170 Watts x 1 @ 4 Ohms
100 Watts RMS x 4 + 260 Watts x 1 @ 2 Ohms
200 Watts RMS x 2 + 170 Watts x 1 @ 4 Ohms
Max Power Rating: 1000 Watts
THD @ Rated Power 1kHz/100Hz: 0.1%
Channel Seperation: 50
Frequency Response Hz (-3dB): 10 - 40kHz (Ch 1 - 4) 10 - 250Hz (Ch 5)
Signal to Noise: >90
Variable Low Pass Filter: 6dB/Octave
Variable High Pass Filter: 6dB/Octave
Input Sensitivity: 0.2-8V
Input Impedance: 20K
Fuse Rating: 25A x 3
will it be ok to run....
http://www.caraudiodirect.co.uk/dynamics-v...0464a068828b291
or would i just be better off getting
I'm looking at gettin another amp of the sub at a later stage, but wil my current one be ok to power either of them two?
Ben.
when it says 2 and 4 ohms, how does it run at these two, better awg wire for more ohms?
the first one the dual 4 ohm sub will be getting 270 rms from your amps 5th channel at 2 ohm
the impedance depends how you wire the 2 coils together dual 4 can be wired to 2 ohm so should run fine
how do i get the 2ohms from the amp thow, is it just a case of something like a 4 or 2 awg power cable for the amp?
no it's the way you wire the 2 coils on the sub to it nothing to do with the amp itself it's the resistance that the subs showing to the amp
how do i wire it then inorder to get the 2ohms, thanks for your reply's mbh.
Ben.
you wire both positives of the sub to the positive on the amp and both negatives of the sub to the negative on the amp ;)
then you get 2 ohm :)
thats great. thanks alot mbh, so i have two from + of the sub to one + on the amp, and two from - of the sub to one - on the amp.
sub amp
Ben.
there are 2 + terminal on a dual voicecoil sub ;) so both the + terminals of the sub to the + terminal on the amps and the same with the negatives
to wire it up to 8 ohm you go amp+ - sub + then the - of the same terminal to the + of the other terminal the the - of that terminal to the - of the amp ;)
i have 5 dual 4 ohm oz audio matrix elite subs for sale i'm after £125 a piece there awesome but i have too much power for them now ;)
specs are on www.directice.co.uk ;)
