Panda's top tip for safe winter driving!
Done my tyre pressures tonight and although they were only a few PSI out, it was enough to make a big difference.
Tyre noise is greatly reduced and the car feels much safer on the road.
For the sake of 20p at the garage, do your pressures people. Well worth it.
Oh and this will also save you money at the pumps too! better MPG with properly inflated tyres!
panda x
  • Replies 27
  • Views 2.6k
For those of you like me, who might find this useful..
PSI - BAR Converter
As the local garage had only in bar, whereas down South, everything is in PSI
if you press the button on the machine that says "BAR/PSI" then it'll do it for you Max.
A good a bit of advice which is useful all year round, not just in winter.
Personally, i'd invest in your own pencil gauge (or similar) and check them yourself at home. Forecourt gauges haven't had an easy life and are rarely accurate....
Edited by Daniel R
20P...for AIR!?!?! We get it free.
You should check your tyre pressures on a bi-weekly basis...at least.
ort leave it until its at 5psi as i found my girlfriends punto rear tyre this morning.
wonder if the price of air will go up with inflation?
lmao, sorry that was terrible.
Blonde + Woman = 5psi in the rear tyre.
I rest my case.
PSI - BAR Converter
I say my man dawn in the sawth of england we have it in bar and PSI :p
PSI - BAR Converter
I just get my bulter to do it while I sip Earl Grey 8-)
she aint blonde so i rest my case.
used to be so maybe it still counts?
Sainsburys give air for free. Morrisons charge monies.
I check my tyre pressures regularly regardless. Specially since I let one slip once and it ended up blowing out at 70MPH (if anyone remember the RR day that I came to in my Derby and I had the destroyed tyre in the boot :lol:).
She was blonde last time I seen her..... she one of those who dye their hair every week like?
Thought she was a natural blonde? Hair dye doesn't count!
Case closed.
Stop being a penis Panda or I will revoke your sticker.
Some guy came into work recently. His tyre pressures were at - 14psi, 22psi, 26psi and (wait for it... ) 1psi. No word of a lie. Completely and utterly dangerous. No care or consideration for his own safety, passengers or anyone else on the road. I made him feel pretty bad about it and he took it on board. Hope he checks them, or at least gets someone else to, in future.
Since I started driving I've always checked mine weekly, if not, more often. It doesn't take long and is something so important but so easy to forget.
i have 15 inch alloys on my mark 4...what tyre pressure should i be putting in? 27 psi is what I'm currently putting in! :)
Do you mean twice weekly or every 2 weeks?
Also, those pop out pencil type pressure gauges are probably worse than the ones at the garage. spend more than £5 and get a propa gauge, if you get one with a dial instad of a digital read out the batteries last forever! :lol:
I've got a white car, what PSI do I nead in my front tyres :lol:
Sensibly though, IMO tyre pressure can depend on many different factors, least of all the size of your wheels. Start with the manufacturers recomendations and put a couple more PSI in for lower profile tyres.
There is no hard and fast rule, somewher between 27 & 32PSI for the front tyres of a small hatch back is IMO a 'safe' pressure
Under inflation will give you heavy stearing, more boat-like handling and worse MPG (with the increase in contact area / rolling friction)
Over inflation will give you lighter stearing and a more positive 'lean in' (to the corner) and better MPG but the decrease in contact area will mean the tyres are actualy less grippy and so will skid more.
I run 31PSI in my front tyres which are 195/45/13.
Edited by RAW
my top tip for winter driving is roll on space savers hahah
30psi all round
23psi at the back (185/70/13)
30-32psi at the front (185/60/13)
Slightly higher for stretched..
Take your summer fat wheels off and get some standard steelies on .
Iff you can put up with the embarrasment that is ..
Thin tyres cut through water / snow fat tyrtes skid across it .
I've got standard 6n steelies on atm :lol: Will be leaving them on for the bad weather..
used to run 27psi all round in my GT running 175/50/13's across 5.5" fronts + 6" rears. had 3psi in the denzeeeeeeeel tyres the other day. nee to check em again cos i think i got slow punctures on all of them but i ent spending any money on the shitter! anyone got 4 part worn 155/70/13's or similar size?
