so I've been contacted about my service
right i know ima geoing to get the hate but i choose kwik fit as every other place was booked up and my polo needed a service befor christmas.
so theyve jsut rang me and said all this needs replacing:
Windscreen washer pump -- Anyone have one for sale? there charging 75pounds.
front brake pads and disks.....only the passenger side needs the pads but them seem to think both
all 4 tyres, which is rubbish as they are new.
All of my bulbs when only the rear brake light was out
all of this comes to £595!!!!
so I've basically said nah as i dotn have that kind of money. ima check over bulbs when get back....and fitting brake pads isnt that hard is it?
My tyres I've checked befor but is there anywhere i can find infomation on how to properly check tyres?
I sweear they do actually rip you off half the time!
rant over...let the hate for choosing kwik fit begin. haha
  • Replies 30
  • Views 1.9k
You can't get shitter than a Kwik-Fit Fitter.
Sounds like they are taking you for a ride. An expensive ride at that. For the pump go to a scrappy. Pads go to GSF car parts are cheap.
Edited by tomadomeit
this is why everywhere else is booked up and kwik fit arent
I forgot the exact tread level u need for tyres but on alot of tyres if you look closly round the tread it might have a sightly raised bit in the tread which is the minimum level. (In my head i know what I'm on about)
Brakes are fairly simple, haynes manual and maybe a mate with some knowledge and your sorted, if your not up for it might be best to get a garage to do it as you don't want to fuck the brakes up and only find out when you need to stop.
The pump, i would leave that, try and get one from a scrapyard and in the meantime just chuck some water over your windscreen before you go out.
Bulbs, check which ones and just go to halfords or some, they cost pennies.
Edited by kerrly
Get it out of there, take it to a real garage/tyre place or do it yourself.
About the one thing they've got right is you renew brake pads as a complete axle set ie, the front left needs doing, you do the front right as well.
Or turn Rogue Traders on them and show up with a mechanic and ask them to demonstrate the faults to him. I had a rim leak on one tyre on the polo so I had a momemt of weakness and went in there, they tried to tell me it was a punctured side wall so the tyre needed replacing and that I should have a 4 way tracking done while I was there "to be safe".
When he couldn't point out the pucture in the sidewall (I'm watching your every move, so don't bother making one) and couldn't explain how they would adjust rear tracking on a fixed beam, I made them reseat the tyre, properly, and seriously cut the price.
Edited by Yeti
With brakes you should always replace both sides in my view, otherwise as the one you didnt replace wears down more, you will get an uneven braking effect.
They are definitely taking you for a ride though, and i can't see how any of that can be too hard even for someone who's never picked up a spanner. Not saying thats you, but don't be afraid to attempt any of it!
Washer pump, go to a breakers and buy it with the resevoir.
Pads, they are correct. Only a fool would change just one side, the uneven braking between worn and new pads could be deadly, plus most motor factors sell brake parts in pairs. May also be worth changing the brake fluid, last time I took it to Kwik fit to change, cost £30 to buy and fit brake hoses and fluid, was actually cheaper that way than to buy a bleeding kit, fluid, brake hoses, brake hose spanner ect.
Tyres, go to a local tyre stockist, tyre shops will usually buy their tyres locally from one stock factor and increase teh price, the stock factor will usually sell and fit tyres like any other garage but you pay a lower price for the tyre. Maidstoen for example has one major tyre stock factor, SE Motor Factors. Bexley tyres also buy their own stock direct but do not supply them to so many other local garages.
Bulbs, GSF shop, VW or your local halfords, bulbs take about 3 seconds to fit.
I think its something like minimum depth on tyre tread is 1.3 mm, but 3mm is recomended especially with teh crappy weather. plus any thing like bulges or damage to the side wall will need a new tyre otherwise it may got pop on motorway at 80mph????
Chris
1.6mm of tread isn't it? And thats the only thing I remember from my driving test :)
They are correct that if your passenger side needs new pads then you should changed both sides, but they are easy enough to do.
As for the rest, it sounds a complete load of bull sh*t, change the bulb yourself, rears are dead easy.
Tyres have to be a minimum of 1.6mm across the central 3/4 of the tyre, go to a local friendly tyre fitter and get them to check them for you, alternatively get a 2p piece and put it into the tread, if it is deeper than the dotted line around the edge of the 2p then there is enough thread on the tyres (providing it covers the central 3/4 of the tyre) and providing that the shoulders haven't gone completely bald.
Hope that makes sense :?
Sal. x
Jesus christ! good job you didnt get suckered in! (shame so many do) kwik fit are a real cowboy outfit IMO, As above really try and get all your parts from GSF or if you can get the pump from scrap. I've got a GSF parts catalogue here but as i dont know your exact model these will be rough prices...
Pump - (golf mk 3 & polo 95>) £12.40 (or if its older the 95 will be about £9.50) part no: 93811
pads - £26.00
discs - £19.50
bulbs will be a couple of quid all in & as for tyres obviously i cant see them nor do i know what size etc but (if) they need replacing try etyres they are very reasonable and come out to fit them same or next day!
pads - £26.00
discs - £19.50
Those prices have shown how much 'Labour' cost they were trying to get, disgusting.
That's where they make their money. The avergage motorist who knows nothing or very little about cars maybe wouldn't realise..
I take it no one likes quick shit then? lololololololololol
Apart from me by the looks of things. I've never had any problems, I thought £30 to buy and fit brake hoses, buy fluid and fill the brake system, done in about 30 minutes was a very good price.
/\/\ The rest of us are not as pretty as you obviously.
HOW MUCH?!?
£595 for discs, pads, tyres and bulbs?
Bulbs would be £5 from halfrauds and any idiot can fit bulbs as long as you get the right one.
Tyres you say are brand new anyway so fair enough.
Discs and pads, order then online along with a haynes manual and if you are brave enough have a go yourself.
Personally I avoid kwik fit at all costs now after they told me they couldn't even fit an exhaust for me. I mean for fuck sake I thought they were professional 'fitters' which specialise in exhausts!
Makes you wonder though how many people they must fool and rip off, if you are one of those who know nothing about cars. Thinking of taking my saxo there for a laugh and see what they say it needs haha.
yeah I've just paid for the service and got my car out of there!
bulbs iknow how to fit, done them all befor,
ima check the wheels when i get in and do the brakes and pumpat the weekend.
thanks for the advice on how to fit though people
£595!! lmao.
I don't know about anywhere else but round here, the fitters all seem thick as! I tried them once, got the price, laughed in the guys face and walked out again!
You have to change the disks and pads on both sides at the front. Basic safety.
As for the price...example...
Tyres £200 .ea
£8 a tyre fitted and ballanced.
Total Tyres = £232
Pads £25
Disks £40
Brake Fluid £5
Total Brakes = £70
Bulbs £5
Total of so far = £307
Not sure where they'd find the other £300. Disks would only take an hour to do and the bulbs all of 10-15mins.
Ask them for the bulbs back they took out, tell them to put your tyres back on and ask why they stole your washer pump.
I bet there is nothing wrong with your car at all.
Edited by tobyk
You nearly took it up the shitter from a kwik-fit fitter! ho ho :-D
That's outrageous! :-(
my windscreen washer wasnt working anyways lol...but thats the least of my worrys!
I'm going to check my tyres tomo as i know the rears are newish.
As for the brake disks and pads I'm ordering from gsf and fitting them myself.
Other than that i can only hope that kwik fit actually did a service on my car instead of working out how much to try and con me!
They must actually make fortunes on the poor people who know nothing about cars and just pay up!
The problem with Kwik-Fit is that they tell you things need replacing when they dont. Biggest con merchants ever.
I had to take my dads company car in to kwik fit get a new tyre yesterday and had an argument about what tyre to put on it. (had just had 4 p-zero's fitted but one got a nail in at th weekend, but he said its not up to me what tyres get put on but thats the ones the company put on recently :s ) They then said it will arrive tomorrow and he said he would definately ring me as soon as it arrived. So i popped in at around half 2 today and asked if it had arrived. The dunce behind the counter said "not as such". So i said well has it arrived then or not? His reply after a short pause, no. Will definately ring as soon as it arrives got to 5 and thought i better go check because the guy didnt seem the brightest and surprise surprise it had arrived. So they started fitting it then confiscated my other wheel bcause i didnt take the punctured tyre back even though they made me take it back and wouldnt keep it GRR they really annoyed me today, i wouldnt have used them personally i would have used another local guy, but since its a company car you have to use themso it doesnt cost anything.
Rant over
John
