9n Grille and lowering
Just wondering will a 9n2 grill fit a 9n? and also if my 9n is currently sitting on 16"s, what difference will a 40mm drop give it, what u think?
not sure about the 9n2 grill u could maybe try and get the measurements for it and see if it would fit you are 9n but i duno if the installation bit is the same. the 40mm drop shoud look tite lad.
hi, a 9n2 grill wont fit mate and 40mm drop should be fine if you have a reletively low tyre profile
I'm currently running a 50mm drop on 205-55-16's (while 15's are getting painted) and get a tiny amount of scrubage hope this helps
