MK3 HELP
basically, i bought some chinese door handles to put on the genesis. and they wont open when i fit them, they lock fine, it just wont open.
and the handle wobbles.
me being the royal penis i am, shut the door. and it wont open. at all. and its the drivers door.
there is a small amount of rust around the hole where the handles goes in.
could that be it making it flex?
HELP!
ste
  • Views 1.2k
Take the handles of form the exterior ..
Iff you had standard Mk3 Handles i could probabbly help but dont know what these look like or how they would fit .
As far as I'm aware the chinese door handles take a little bit of fabrication. If the door won't open then theres obviously something not connected or in place.
I assume you have removed the door card to see the internals?
you have to remove the "flipper" part from the original handles and fit it to the chinese handles. Takes a bit of messing about but does work. I can't remember the exact process as it was years ago I fitted mine to my G40 but I remember also having to bend the striker plate inside the door that the flipper pushes on to get it in the right position for the handles to work.
