tt pedals
hi all need some help. i have just bought some tt pedals and my accelerator pedal is too big for the tt pedal to go over . can anybody shed some light on how to get it to fit :cry:
  • Replies 14
  • Views 1.4k
It does fit. It's just abit awkward. Try clipping the bottom on first and work your way up the pedal. You may need to use something like a sticky pad/tape or super glue (I imagine it would be very hard to take off after though!) to stop it from falling off.
Edited by CymruPolo
theres a thin plastic cover on the accelarator pedal you have to pull off, give it a yank and it should pop off then it should fit nicely!
thanks for your help i will have a go tomorrow
no problem!
I was struggling for ages to try and fit it before I realized that thin cover, stuck mine on with some super glue and its been fine since!
anyone got pics of these fitted???
Yeah pics please :D
i'll get some in a bit.
No glue is needed.
You have to bend the accelerator pedal and it fits OR use a LHD one.
my cars sooo dirty inside at the mo lol, as test richie said no glue necessary!
:D
You've got mud all over the clutch pedal! oohh look at it! :(
still no joy with the tt accelerator pedal.. it just dont want to go on. :-( is the LHD accelerator pedal bigger than the RHD accelerator pedal ??
i built up some double sided number plate tape onto the base of my accelerator pedal once i had bent it into a better shape for greater contact with the pedal...never budged!
