GEAR BOX FOR 6N
Hi all wanting a gear box for a polo 6n 1.4 8v the MPI one help with were i can get one if none are upfor sale
  • Views 486
If you know the code, there may be others that have the same ratios.
were would i find the code
If the box is off the car, it's stamped in the top of the bellhousing between the top 2 mounting bolt holes. If it's still on the car, there may be a build label in the boot somewhere. Alternatively, you could ring up your local dealers and they should be able to tell you from the registration or chassis number.
am breaking a '97 polo 1.4 mpi and will have the box out today,shall look for the code for you.....is your box a rod change box or cable?? laters joe
