Come JanuaryI want a MK2 GT..
Right guys.. At the moment I have a MK3 GT with a very strong engine and average body.
I'm wanting an old but mint MK2 'S', maybe a breadvan or saloon... Depends on what i find first.
I will be activly looking from january. I just need info on what needs to be done for the full conversion (MODS: Didn't put this in technical section as it covers it all)
Basically I will be transfering the whole GT setup..
Thats engine, zorst, looms and the full brakes (including master cylinder, compensator etc.)
Now firstly, if in a saloon what makes the exhaust longer? I have a powerflow for a coupe I want to keep, what section needs lengthing to convert it to sallon length?
The clocks, Can I use MK2 clocks for a GT engine? (Early H reg GT lump running on standard ECU and injectors) or use the original mk3 GT clocks?
Brakes, How easy is a MK2 tricked out with full GT/G40 brakes?
Edited by MrP
  • Replies 19
  • Views 1.5k
You only need to add the electric fuel pump part the wiring to the car so you can keep the original clocks! Obviously under the bonnett the whole engine loom will need changing but i'm sure you knew that already!
Brakes wise, my brother is running a Mk2 Coupe S with a Gt conversion and G40 brakes, however, because there is no servo the brakes still arent the greatest! Get yourself some decent pads and it will make a hell of a difference!
Awsome.. I will ask nearer the time on the fuel pump wiring.. So the dasj loom can stay?
I want to swap the servo tho.. Is it possible? I've been told the car needs cutting up!
Yeh all the dash loom can be kept the same. All your taking from the donor car is the extra bit of wiring that goes to the fuel pumps! Pretty easy to do, and can be taken from any Mk3 Polo!
You can swap the servo but yes you do have to cut most of the Mk2 Bulkhead away and weld in the Mk3 bulkhead which has the mounting points for a servo! Its a LOT of work!
Shit.. I need good brakes! Thats messed my plan up!
All you need to keep in mind is that a servo doesnt make the brakes any better, it just assists in the pressure put through the system! So to get them to work aswell as a car with a servo you have to push the pedal twice as hard! It takes a little getting used to but once you are used to it you wont even realise your doing it!
If you use the G40 (VWII) brake set-up with decent pads and disc's with some good quality 4 DOT or even 5.1 DOT fluid and braided pipes the brakes should be more than enough to stop a GT.
I have G40 brakes and a 22mm master cylinder at the mo!
Then I would think that would be fine then. Just add the good pads, discs , etc.
There are a couple of companies like Hi-Spec who do bolt on big brake conversions for Mk1 Golfs. So I don't know if it would be possible to fit these to the Mk2 Polo as I know Mk1 golfs and Sciroccos can be brake donors for the VWII callipers. Have a look here.... If it would work then I'm sure it would give you decent stopping power. but I think you will need 15+ wheels to fit over them.. :-(
Mark
Edited by max_crox
i bet i could haul my car up just as quick as a mk3. I'd just have to press the pedal harder.
With vented discs, braided steel lines, correctly adjusted rears, and good fluid, the stopping power is enough for a gt.
Even a 100+bhp GT? Thats what I'm aiming for.
As long as you can press the pedal hard enough, a Mk2 and Mk3 with the same brakes have no advantage over each other, apart from maybe the increased feel from the non-servo assisted mk2!
Yep. They were used as std to stop the 115bhp G40 and I guess are still used to stop a lot of the tuned versions as well. So with braided hoses, decent disc's, pads and fluid then it should work fine. Also as the Mk2 is lighter than the Mk3 (granted only a bit) and if you are going to strip it out as well then that would mean the brakes will become more effective as well due to slowing less mass.
If you are after more stopping power you could look at a rear disc conversion or use the Passat rear drums. This should add some power but I dont think it would be that much, But every little bit helps :)
Mark
Right.. So whatr about the rear brake compensator? not worth it?
Or.. rather than going through all this effort just look for a later model mk2. My 88 coupe S definatly had servo assisted breaks. And I had mk2 golf GTI discs (same as G40) ready to go on, and had trial fitted them, worked fine, all you need is the rotors and some VWII callipers, nothing else was needed. But yeah, my breaks were identical to mk3s and would lock the wheels at 60 easy enough, just faded a bit if ragging it.
If your 1988 mk2 had a servo, then it would have been fitted with an aftermarket BRM conversion kit. Or was it a LHD mk2????
My mk2 breadvan is using G40 front brakes with uprated pads and discs and mk3 gt rear brakes (no load compensator though) with no problems at all. As said above, you need to push that little bit harder, especially when you have 190'ish bhp under your right foot lol
Edited by LregG
i didn't bother with the load compensator cos i was told it goes to shit when you lower the car anyway.
It will do because of the way it works - when the axle is closer to the car, it thinks there is more weight, therefore bumps the rear brake bias up!
But, you can have them adjusted. If it's worth it...
Oh right? thats odd. It definatly looks standard fitment, and its definatly there. Doesn't seem as powerfull servo as on my golf but it is there. Well if you want it I'm splitting the car? haha.
