engine dampness
right i have been having trouble starting my car as a few people know !!! i have changed the ignition lead and it has started really well for four days until now its gone again ??? any sugestions on what it could be my dad recons it could be the spark plus have got a hair line crack in them or something
really need this problem sorted
thanks matt !!!
  • Views 1.2k
thanks matt !!!
try the earth wire. there is one behind battery thick flat thing. mines was worn. real simle to replace and only a few pounds to buy. its worth a try
cheers will check it tomoorow any one else have any ideas ?
I'm having the same problem...
I thought it was damp on the plugs and distribution box... So i cleaned up and gave em all a good spray with WD-40. Seemed to resolve the problem for about a week. But I went to start the car again this morning and it just cut out straight away.
Not good. :(
Is this a common thing in Mk4 6n's then?
Edited by Smidley
Not good. :(
i have changed my dizzy and rotor arm seems to be runnign better than it did still fubared tho !
got same problem... askd mechanic... sumat to do with spark plugs..
