part numbers
6n0 805 903 E - 6n2 GTI Splitter
357412341A - 6n Topmount
N 10418501 ------- |
N 10418502 ------- |--- These should be HT leads for an AFH (6n 16v)
N 10418503 ------- |
N 10418504 ----- |
can someone check i've got the right part numbers please ? if they're wrong can i know the right ones! also need the part number for a temperature sender for a 6n 16v (AFH)
cheers!
Edited by Foxie
  • Views 1.3k
Can check when i get home if no one has done it for you by then
Join Vagcat.
The ignition leads are the right no.s.
I think the topmount is 6N0412331A which is the big lump that sits above the spring seat under the bodywork.
The spoiler part no. is also correct.
There are 2 temp senders:
6N0906088 - 6N-W-001 000
1J0906086 - 6N-W-001 001
think there is a part numbers thread somewhr mate, might get more luck there :thumbsup:
