Hammerite
Right. Bought some smooth white paint for my wheels, in tin form. It runs, its a faf. Is the spray on stuff any good? Does it run less? Last long enough for some wheels and a few strut bars?
Any help
cheers
  • Views 1.4k
if it runs you are either doing it somewhere too cold and/or putting too much on! the key is to do it somewhere warm and use a very soft fine brush, you should be able to get a reasonably smooth finish. I use a 5mm artist brush when hand painting alloy wheels, takes a while but its worth it
the hammerite is quite thick, sticks very good to...
