badgeless grill
recived my grill this morning, i just removed the old grill and tried to fit the new one, but it doesnt seem to be fitting. the 2 grills look exactly the same but the clips and holes arent lining up.
any tips!!
thanks in advance
  • Replies 8
  • Views 1.5k
Are you putting it the right way round? Also have you ordered it for the right model, mine fitted in with no problem
Mine was a tight fit and took a bit of work to make the clips go where they're supposed to, but nothing complicated..
yes, defo the correct one.
yes it seems like a tight fit, just scared incase i break it. its as if the clips on the new one need to go down a bit.
Where'd you get it from? thats the problem I had, but it does fit!
It will fit chap, when i was fitting mine it was really tight. But i used a flat head screwdriver to push the clips down a bit, and it fitted fine. :thumbsup:
venom website.
I'm also in the middle of fitting golf seats to my polo, I'm off all week from work, and this grill is doing my head in as i dont want to break it.
thats it fitted, broke one of the clips but its not visable. ill post pics up tomorrow.
