filler for bumpers
need to know what the best filler is out there for bumpers
  • Replies 10
  • Views 1.5k
plastic bumper filler! you can get special filler for plastics that wont crack like normal car body filler would
plastic padding elastic filler
thats what I've used on mine
when filling mate build it up in thin layers as it makes it stronger and not one big clump :thumbsup:
ah ok cheers mate, just went and bought some of that loctite body filler which I'm pretty sure will be alright for plastic bumpers but what grade paper should i use to sand it down, any ideas ??
could u just put filler in the side grills on a 16v bumper? then sand over it then paint?
once the filler is applied and just over the surface level
start with a p80grit disc to get the shape
now use a p320 to get it almost flush
then a p120 disc
now apply a stopper
and finally a p500 disc
prime then wet flatten
check for imperfections and correct
then paint ( i would now wipe over with a tak rag ) and lacquer
wet flat again and machine polish then glaze
and finality polish and wax
all done any prob's just PM me :thumbsup:
ah ok cheers for the advice mate, and yeah if i do have any probs i will drop you a pm :thumbsup:
then a p120 disc
now apply a stopper
stopper? wet flatten?
stopper is a very fine filler that will smooth out any air holes and light scratches that may be left in the filler after sanding i use a 3m red putty
and wet flatten is just wet and dry sanding :-D
