pic request, gt engine bay.
could someone do me a massive favour please?
take a pic of the side of there gt block from passenger side so i can see where all the coolant pipes go, cheers
rob/ flat-eric
  • Replies 11
  • Views 1.4k
Now i don't know i this helps but this is a pic from my Mk2 Coupe S. I'm just in process of doing the same conversion as you and I have taken nearly 100 photos of the GT engine bay bar the one you are after!!! :)
If you still need one I can get one done tomorrow when it is light!! :)
Here is the Mk2 Minus the rad but with the pipes installed
Mark
Edited by max_crox
Mark
not quiet but close, need the other side of the dizzy.
top tip, get all the wiring from the gt and you will need to change all the looms including the headlights one.
Ok I'll see what I can find in my photo folder...
I'm quite lucky as I have a full donor car to strip! :)
Mark
Here is a pic i have found out but I'm not sure if it's what you are after??GTSquarebackengine.jpg
Dan
well thats two wires identified! the gt header tank is different! lol
i need the other side of the bay kinda down the back ish but tanks anyway as you've sorted two wires out! :nod:
Mk3 GT
Edited by max_crox
max crox !!!! you are a legend!!!!!!!!!
that is gonna be so handy!!!!!!!!!!!
and will solve my problem!!!
cheers!
max, was the picture of that engine taken when it was in and running? if so why are you missing a pipe shown by the red line on this picture? (bottom left)
On a GT there is no pipe there.
Its only used by spi's iirc.
if there is a pipe on yours as you shown someone has used a spi thermostat housing and blocked it up with a pipe.
cheers!
Well I have always told people I was but no one believed me!!!!! :lol:
If you need any more let me know as I said I have about 100 of them!
Mark.....
does this matter? does it change anything?
