Can a AFH sound any better?
  • Replies 18
  • Views 1.5k
That sounds too beefy for my liking, it would only make sense if it was running stupid power.
On ITB's It might be running 140? depends on the spec!
its on bike carbs not itbs but still sounds sick thinking about doing similar
Oh yea sorry my mistake! haha! i just looked at the video and thought it looked like it
cheers guys, its my car :) its on bike carbs with a SS 4 branch with a straight through exhaust at the moment.
since then the ignition timing has been done and it will be going for a full SS system and carb setup to shut it up abit!!
Chris
that sounds the dogs.....so throaty
top work 8-) 8-) 8-)
pretty cool.
bet its fast
start you fecker :badgrin: Sounds good
that sounds immense
How much did it cost.
my god....
haha starting issues now gone :)
it wants to go but just aint got the right fueling so until its setup correctly it wont be going anywhere fast!!
cost -
afh engine including wiring, inlet, alternator, pas, exhaust manifold, etc - £100
GSXR750 carbs - £15
SS 4 branch - £120
8p gearbox - £0
G40 clutch - £75
Cambelt Kit - £55
still got some bits off the afh engine that i didnt use if anyone wants them
Chris
Looks a bargain build imo!
Sounds amazing tbh. And good price too!
What are the gains from this?
Any idea what this would put out?
Edited by Dub1
what are you running ignition setup?
The gains for me are -
the original 1.3 8v was boring and slow at 45bhp so I'm hoping for abit of an increase ?!?!
power, i aiming for 115 when its set up as it is now, dependent of smiles per miles i would like to fit a pair of high lift cams and do some headwork. engine management would be nivce to :)
Ignition - using the old stuff out the mk1 as someone had previously converted it to hall effect dissy, the connector just pluged from one dissy to the other :) i believe it is mk2 golf stuff that has ben used with the separate coil and amp.
Chris
so the carb setup gives you an extra 15bhp :?
love to do this especially for the price of the setup sounds amazing a bit too beefy tho :)
Edited by dhali
