Sunroof seals...
Hi, recently my sunroofs been leaking, not good for this time of year, getting into a car with a puddle on the seats and dripping water as you go round corners...
Just wandering where to order a replacement seal for my sunroof
I drive a Polo 1.4 6N 1998 but i think the sunroof was fitted after manufacture as its different to the other polo sunroofs I've seen (the rotating handle ones). Sunroofs made by Sekurit. Anyone know somewhere to get the new seal? Also how much am i looking to pay out for this?
Cheers, much appreciated
Joe
  • Views 3.3k
Joe
doubt the sunroof is made by sekurit that'll be the glass. could be wrong like.
spray lots of hairspray around it that will keep it water tight until you can get new seals...
I think you can make your old seals good again... try cleaning them up, maybe use an old toothbrush or something. Not too abrasive, then get some silicone spray on them should do the trick :)
cheers guys il give it a go... :thumbsup:
if you just want seal it short term untill you can repair when the rain stops,smear some thick grease or vasaline(sp)on the seal while the sun roof is open then shut it.should seal it until you can fix.
worked a treat on my old escort
