little strip under the lights on a mk2....square lamps going on!!
Right, i have a square lamp grille and lights which are ready to go on my car.....
I added a pic to show you..... i cleaned the lenses inside and out and sanded back the rust on the back of them and gave them a lick of paint..... look like new :-)
My problem is that on the mk2 there is a thin metal stip between the bottom of the grill and the top of the bumper. This dips down slightly at either to go with the shape of the original round lamps..... Is this hugely noticable when everything is fitted??
Also how easy is the fitment?? Just a few screws and clips?? and are they in the same places for boths grills?? Any help would be great!! :-)
Edited by demolover
  • Views 1.2k
Put BLutack in the dips and spray it black, noone will ever know. Or you could attack it with filler, and spray the whole section to match the eyebrow. Just the first thing that came to mind!
I was thinking the same.......hmmmmmm
wouldn't be hard to paint that little bit
I think mine was really scabby when i got the car - it's not that noticable a part so the finish doesn't have to be top notch, and there's nothing really to blend into - so the colour match hasn't got to be perfect either. Attack it with some pliars and filler and paint, should beable to make a good job of it without too much stress I'd immagine! good luck :)
i may just paint it satin black rather than colour match as this would be easier to get right and wouldn't look weird as its right under the grill.... think i will give it a go this wknd!! :-)
whered you get the grille and lights? I'm after some
Someone on here was selling them and i responded first. They are never cheap though as they are hard to find. Barely ever come up, well i ahven't seen many sets hence why i grabbed these with both hands and threw my wallet at them!! Just needed a bit of a clean up and the grill badge swapping.....few clips missing but i will get it to fit securely somehow. Good luck finding some but don't hold your breath..... keep your eyes open and some may come up!! :-)
all fitted now, with new bulbs and sidelights and it looks awesome. Will get some piccys up soon.
Didn't even need to worry about the little dips as the chrome strip at the bottom of the squarelamp grill actually covers it.
Silly me!! :oops:
