eyebrow spoiler......?? mk2
I have an eyebrow spoiler which i bought from someone on here. It came with just the eyebrow no fittings. How the hell do you get it fit?? What did the original fitting kit comprise of?? Sorry i may sounds like a tard but i didn't want to go attaching it in the wrong place the wrong way and regretting it!!
Any help??...... someone must have attached one!!
cheers
  • Replies 11
  • Views 3.3k
Any ideas?? I need it to cover the bonnet gap. My car looks whack!!
If it's a metal one, with a welder.
Its a plastic one whcih i have painted...... kamei ro something similar is the name of the make. I have no idea how the original fixtures worked as it came with nothing. I expected it to be more obvious to be honest :-)
drill holes then screw it on with self tappers, or you could glue it on with tigerseal or other similar silicone sealant
drill hole through spoiler and slam panel, attach with self tapers. just remember to give the slam panel a little paint after drilling to stop rust.
they screw onto the grill not the slam panel.
Make sure you fix it securely cos they have a habit of flying off at speed.
I bonded mine on, on my BMW 316 i imagine the same will work !!
depends on the make how they fit
Cheers for the help. I will get a pic up of the part in question.
A) i don't want it to fly off at speed.
B) I have recently put on a grill and lights on my car from a squarelamp derby so i would rather avoid drilling holes in the grill.
Thanks for all the help. Think the make is kamei or however you spell it!! :-)
Barney
the screw onto the grill
thats how mine is done and it hasn't moved in the 2 years its been fitted
cheers
the plastic full width ones have several holes where they fit over the grill. screw some self tappers through into the top of the grill.
