Anyone else got a race technology or G-tech performance meter
Bought one a couple of weeks back. They're pretty fun little gadgets only had time to use it a couple of times. Was wondering if anyones compared the data to a rolling road and 1/4 mile data.
My GT reads 71 bhp at the wheels
1/4 mile was about 18secs in the damp
0-60 was 9 secs in the damp.
  • Replies 10
  • Views 1.6k
i dont no how to use mine :S :lol:
I got the RR.
Managed a 17.4 1/4 in a slack oily 1.8 GTI 8v Golf.
It seems reasonably repeatable, and doesn't give your car batmobile bragging right figures so I'd say it's pretty good.
hmm interesting - how does it work? Anyone got a BHP reading from one, against an RR printout?
It uses accellerometers to gauge G force over time, and thus distance over time. As for estimating BHP, god knows and it doesn't interest me much for that side of things.
It must use some simple Newtonian physics to guesstimate energy required to accellerate a weight that you enter in the amount of time it takes to cover 1/4 mile. However the figure it gives you isn't at the wheel, it's how much BHP is left after not just the wheels, but rolling resistance and most importantly, air resistance too. However, it does seem to be quite repeatable so if it can't give you a meaningful figure, it seems atleast reliable enough in telling you if you've lost of gained anything.
Because of the amount of variables involved, you wont realistically be able to gauge a very minor improvement though unless you averaged out a lot of runs before and after. That said they're quite entertaining at giving you a somewhat educated ballpark guess.
Edited by EeekiE
You can work out your 0-60 by either using the standard way of it telling you (which I don't trust),
Or you can match up the Y axis (RPM) with the X Axis (Time) and see when you are at 60mph in 3rd gear, after taking rolling radius into account.
A good half a year ago I did this and it come out at 13.4, but if I did it again under the same conditions I know I could beat it by a fair whack - so it helps to show you how you improve and how consistent your times are.
I've got one of the old crappy first generation G-Tech meters. It seemed to think that the Saab was making 320bhp or so, lol. The newer ones seem to be a lot better though, and the Race Tech one I've seen in use seemed to give sensible results.
mines the ap22 race technolgy one. Its uses a micro chip with a tiny weight in silicone on it or something like that. I only really bought it for fun. haven't set up the rolling resistance etc yet.
I've got the Ap22, They're not that accurate, they make your car seem a little faster. On a drag in my dads car it said it did it in 13.09secs, yet the actual timing at the pod said it was 13.64's or something. But its accurate enough :)
you're best using such things for making back to back comparisons for adjustments on the car, and seeing if something works better or not rather than seeing the size of difference. if calibrated rolling roads show different figures for the same car, a gadget thats got even more variables will be less accurate.
Yeah that's all they're usefull for in reality. However, has anyone used one of them driveshaft dynos? They're like a torus that slips onto the driveshaft to measure inertia.
