mk3 water leak
I've got water leaking in the car when its raining. Its coming in between the spot welds in the pic below. Where abouts wil the water be coming from? Its coming in both sides, bit more on passengers.
  • Views 1.4k
I've stripped my G40 to the shell, and i cant even see which part of the car is in that picture.
help us out mate - we need more of a description of the area - drivers side and passengers side narrows it down a bit but not much!
Just incase you couldnt tell i took another pic. The pic is drivers side and the crossmember(?) runs accross the front under windscreen. Only leaks at each edge though.
probably getting round the windscreen seal? Are there any signs of rust around the bottom edge of the windscreen?
When i took windscreen out there are 2 holes at bottom of the windscreen. They look like there meant to be there though. Wernt really rusty to be honest. Just cant figure out how water would get there.
the holes are there to let condensation out, just cover them with tape and refit window with windscreen sealant and original seal , or better still new seal and sealant, your original seal is knackered,,
Think ill change it and silicon the holes up. Its the 5th :shock: windscreen that the seal has seen. Is tht where it ill be coming from them holes then?
mine did the same, so i welded them up,
i think that the water comes in through the fusebox, and by the battery
