GT'd mk1 on bike carbs, P+P head, cam etc
Got round to getting the bike carbs on......
Only got her running around an hour ago. The video is loud due to the exhaust not being connected
Can't wait to hook up everything properly and drive her :-D
Edited by LregG
  • Replies 62
  • Views 7.2k
swanky
was it hard in the end?
swanky
Still got to sort out the throttle cable, choke cable and water pipes. I've also got to mount the facet pump and filter king head and wire up the pump properly and connect up the exhaust.
Really want to hear it without the exhaust drowning out the induction noise
Was the manifold easy to make up?
What did you use for it?
It wasn't too bad to be honest, i used 38mm o.d. steel pipe for strength.
Inlet runners 2+3 line up just fine but 1+4 have to be offset a little
Edited by LregG
That does sound sexy m8 .
i have been fancying carbing by 1.3 (2g) on a set of bike carbs.
has it been hard work getting them on.
I take it you made 4 steel plates up used a 38mm hole saw and then welded the tube in the holes using a mig welder or similar?
Making the manifold was the bit i got stuck on when i was proceeding ahead with my bike carb project
That's about the long and short of it, yeah
Any reason why you can't cut the flange of an existing inlet manifold, then drill that, then port match it to the head, and weld tubes onto it? Could that work?
Yeah that'll work
Very swanky indeed. Are the wheels you bought off me at e38 being used on the Mk1?
OK cool.
Couple more questions; is the flywheel a machined standard item, or not? And what ignition setup is that, I can't see the vacuum advance?
The standard polo inlet manifold is a strange alloy isnt it?
Can imagine that it could be very hard to weld
Making metal plates is easy peasy anyways, my problem was not being able to weld
looks very sweet mate, no sound on the computer atm but will watch again to get the full effect
Awesome work mate, look forward to seeing it complete.
You seem to have an ability to knock out quality polos without seemingly trying!
sounds sweet, like you said be nice to hear it with an exhaust on. top work!
quite a cool fleet of polos you're building up there mate!
Any chance of writing a how-to guide? Daft as it sounds, I'm interested in this as are a couple of a my friends, and others on here too I'm sure. Would be really helpful!
Looks like you've done a quality job though. What bike are the carbs off?
what cam? 268,268?
also, what pressure are you running carbs at? just making sure i get the right fuel pump. Thanks.
nice one :thumbsup:
cheers tom :-D
Thanks mate :-D
The ignition set up is from an MH engine which is found in post '85 polo coupe S's and mk2 golf 1.3's. There is a vacuum take off for advance on inlet runner number 4 which is out of sight.
I'm using a facet electrical interrupter type pump with a filter king filter/pressure regulator for fuel delivery.
The bike carbs are off of a CBR 600
The cam will be a PSD P1NA 268/268 but for the moment (few teething problems to sort out) i'm using a standard GT cam
this time after the exhaust has been adapted and bolted up together so you can hear the induction noise (tappets have not yet settled in!)
Cheers mate, my setup is going to be very similar! Except a guy at work will fabricate the manifold for me once i Cad it up.
