polishing buffer?
hey guys
am looking to buy a buffer for my car :)
any ideas which is the best ones to go for??
i have no idea at all
thanks guys :)
  • Replies 14
  • Views 2k
bump??
any 1
i just got this cheap 1 from screwfix direct.
works a charm :) does the job mint.
£14.99
Mine's a cheap arse blackspur job. It works fine, the key is in getting good pads, especcially the off pad (get a lambswool).
The best way to do it is persuade your mate to buy one as well, then do both cars at once, follow each other round, one putting polish on, the other buffing off.
Edited by Yeti
www.detailingworld.co.uk
is your friend
get a porta cable and you will never look back
is your friend
aye matey :D
am a member on there
some chaps are awesome at cleaning !!
what is that man?
its a type of variable speed buffer check this on ebay item no 150194461409 i cant get a link to work to it
they are brilliant and its nearly impossible to burn the paint and its what most of the pro's use.
Edited by pologti76
Meguairs do 1 also!
http://www.elitecarcare.co.uk/index.php?cP...1cf26698587f8ca
Just been released and apparently the dogs danglies!
I am just waiting on reviews from the UK users and some good package deals and I think all going well I will get one!
Bolly
pc's are cheaper and proven technology lol I'm sure the meguirs 1 will be good tho
is your friend
aye matey :D
Me too, joined recently and got a UDM on the way from the states :) Had a go on a PC at the midlands christmas meet a few weeks ago and even a noob like me could do it!
I just got a Meguiars G220 Dual Action polisher today, this is essentially a Porter Cable designed for UK mains voltage.
I can't wait to give it a whirl...goodbye to all those swirls!!! :-D
Mahbs
i would highly recmmend you get one like "pologti76" showed you. cant go wrong with it- paintwork near impossible to damage with it and end results are maginifcant. however it wont get rid of all your swirls and scratchers. you could opt for a rotary. however can burn through paint, but end results are fantatsic. its what the pro detailers use.
As far as I know the PC 7424 and the Meguiars G220 are assembled in the same factory.
Advantage of the Meg's machine is that it is UK voltage rated 220-240v so no need for a huge stepdown transformer and leads needed to run a PC at 110v and Meg's UK warranty. If you factor in the cost of the transformer/leads and import duty etc, for the PC the price difference is marginal.
Mahbs
