arch rolling/stretching
i'm a bit new to this so you'll have to bear with me if i don't know all of the correct terms, but basically i got some new wheels for my mk2 square back, and the rear wheels are too fat and don't fit inside the rear arches. i know a place where i can get them done professionally, but i was wondering if anyone has attempted this themselves, and if so, how hard is it?
would i need any special tools. has any one got any pics of how they did it or anything like that. any pics of what it looks like afterwards?
cheers for any help.
Tom
Normally they bolt an arm n roller on the axle to produce a matching curve when flattening/fattening the arch but aint got a clue with the squareback rear
Check this thread because it covers your predicament well kind of.
http://www.clubpolo.co.uk/forum/index.php?showtopic=88755
I'm not a fan of messing with the rear arch on a breadvan, basically because it's really hard to do nice because it's not a sweeping curve like the front arch. You could maybe bend the inner lip in but that can catch water and road salt unless you fill it but not ideal, maybe trim some inner lip out but not much for strength.
The offset of your wheels might simply not fit the breadvan but I'm no wheels expert. I wouldn't go any wider than 6j which might need stretch on the tyre. Use the search engine on the forum because this issue is covered a lot.
Someone needs to sticky something on this like Heartagram did with the Minilites offset problems...
Cheers Dunc
