bumped my car
Bludi bumped my car today, had my bros wheels in the car, and had one on the front seat, 17inch wheel with a tyre was rather close to the gear stick, i pulled up behind my step dads BT van, and it has a plastic step on the back of it, went to put my car into reverse and selected first because it was tight iwth the wheel on the front seat, and then let the clutch up and ran up the step grrr, so a then found reverse, backed off the step.
cracked abit off the lower plastic insert on the metal bumper, and bent the bumper rather badly.
but took the plastic skirt off then the metal bumper, bent it back into shape, and stightend out the fixing brakets on the car, and will refix the bumper tomorrow in the light.
was so annoyed that i had damaged the bumper that i stripped it all off and strightend it out, using only the light on my phone.
how much will it cost for the plastic insert for the bumper - its a 6n 8v.
  • Views 1.2k
Don't you have to push down for reverse? :roll:
Won't cost much I shouldn't think! Get down a scrappers..
ye, push down for reverse, but i didnt get it across far enough because of the big dopey 17inch wheel and tyre on the passanger seat.
i took the bumper off, bent it back into position, and put it all back together, and its gone back on, and it all sat back in fine with abit of perswation.
