How do i make my MK3 Undriveable?
Going somewhere a bit dodgy tomorrow night and don't want my car to get nicked.
Whats the quickest and easiest thing or things to take off the engine to make it unstealable?!
  • Replies 49
  • Views 4k
Unplug the HT leads 8-)
Coil lead
Fuel pump relay
Put it in gear and loosen off the gear selector too I reckon
Edited by tobyk
maybe something for future maybe a quick release battery cable handle thing.. they use them in motorsport with the red handle.. spray that black and you can put it next to your battery somewhere discreet :D
Only leaving it for 3 hours and everything has to be put backable in the dark!
Coil lead
Fuel pump relay
And wheres the coil lead and fuel pump relay?!
I used to change the ignition leads round on one of my cars so that the igniton fired at the bottom of the stroke. I guess thought it would be something that was pretty hard to spot
I'd go for the rotor arm mate, stick it in your pocket. or hide it somewhere in the car..... It's small enough to carry and the type of retard thats gonna try n nick your car won't know whats going on. 8-)
Just unplug the hall sender and tuck the connector underneath. No one is going to waste their time looking for it in the dark.
I'd just take the lead that connects to the coil...one thing and it's really easy to remove/refit. If you go messing with HT leads you might not manage to get them back on in the right order in the dark.
How dodgy is this placE? 3 hours and you're going to this extent?
Surely if someone can't get your car started they are just going to destroy whatever else they can in the mean while?! :? I think I'd rather get back to no car than see my pride and joy smashed up!
He said he's off to Bristol...maybe he should take the bus eh?
:lol:
lols urely it wont be that bad for only 3 hours :shock: I'm sure if its in a populated enough area that will be abit of a deterant?
Just disconnect the battery? lol! Noones gonna open the bonnet and look around.
If you're really bothered, switch 2 leads.
Just remember which 2 though.
take the wheels off?
or just one?
takin the coil lead is the easiest option, or disconnect a plug from the throttle body???
I agree with Tav. I say you take the bus if it's Bristol you're heading to.
If not, siphon out the fuel, drink it and throw it back up into your tank before you go home. :lol:
Steering wheels just one 24mm socket. easy as hell to take off, and that way the can see theres no point in trying before they've already smashed up your car to break into it, and botched the wiring to hot-wire it.
hall sender plug on to of dizzy. Unplug and leave it loose. Car ain't gunna start then as there is no spark.
Don't just take one HT lead off a car will still drive on 3 or even 2 cylinders. Be careful if it doesn't start the might just torch it to get rid of any evidence.
Matt
jus take the king lead of the coil.
shit what part of bristol u parking your car in saint Pauls!
get a big dog, starve it for 24 hours and leave it sat in the car (as long as it doesn't try to kill you on the way there or when you get in the car afterwards.
