what are the orange marks...
just wonderin what they are,
there is on just over 20mph (has one orange line),
one just over 40mph (two lines)
and and another at 60mph (three lines).
they are 3-4 mm long and are on the speedo.
Are they to do with the gears?
  • Replies 23
  • Views 1.9k
If I remember correctly they are indicators for you to change gear. I think its to enable you to get the best mpg by changing gear at the optimum time.
Orange line it!! I dare you to get 50mpg! Go on!
Limiter in each gear?
Its no where near the limiter.
I think it is for fuel economy as they are all near enough at 3,000rpm, found that out when i fitted the rev counter in mine. Was changing gear well too early when i first got the car. It amazing how quick the car is if you just keep going in each gear hehe.
i thought they were something to do with the gear changes but i didnt want to rev that high (not had it long and i want
to give it a service first)
what do they rev too?
They hit the limiter at just over 6,500rpm, a few breathing mods and the engine loves hitting that limiter, well mine did anyway.
so they dont keep trying to rev, the limiter stops it from 'blowing up'
The engines will happily rev to 8K if you were to get a chip but yeah they are stopped by the electronic fuel injection at 6,500rpm so unless you keep it there for a week it will be ok.
thanks, 1 less thing to think about :D
Yeah if you have a carb motor without a rev limiter the only thing that stops them from revving is valve float... They'll hit 9k standard! :lol:
ye, in my first car same angine as yours, it was the same,i figured it out after a while.. only after i noticed them after driving it for about 3 months lol. i used to love hitting the limiter in my polo. the mondeo i have now sound more like a diesel flat lining :(
its like a tube of pringles
once you hit the limiter you wont stop.. for a good while anyway
Surely 2 lines means 2nd gear and at 40mph...that's not very good for economy?
Yeah but your piston ended with a hole in it?
Edited by Tav
I remember the first time I took my mk4 1.4 8v out after selling my 1043 mk2 carb with no limiter. I thought it was broken when I hit the limiter in second after nowhere near as much fun as the mk2. I guess 9k isn't too far from the truth, I never put a meter on it to find out just how high it would rev, but it was a lot further than what's probably healthy! lol.
much love for the industrucatble 1043 :)
I caned my 1.0L off the rev limited loads and loads of times, never serviced it and it lived on and on until eventually pouring lots of thinners, oil, primer, hardener and various other substances down the throttle body and filling the engine up with water did it die. Even then it wanted to turn over but wouldn't fire cause it was a bit damp :lol:
Bomb prooof I tell you!
Shame you cut the cambelt really
I didn't want to cut it. I wanted to drain some of the water out and fire it up again.
Rich and his stupid ginger beard thought it would be a good idea though :roll:
Thats why you should never have baldy ginger bearded friends from Durham!
:lol:
I want another 1.0 Polo I think
Although a 1.3 would be better in every single way lol
To clarify:
Those orange lines are 'change up' indicators and refer to the maximum speed for each gear (1 line = 1st gear etc) and are therefore not for economy purposes.
However, the choice of speed for each gear is a bit odd and confusing should they be fitted to model which also has a rev counter, simply because they don't refer to the maximum permissible engine speed of either the handbook or rev counter (6300 rpm). More often than not, they were drawn in line with peak power, 5200rpm if it's a 1.3:
1st = 24mph = 5300rpm
2nd = 43mph = 5375rpm
3rd= 68mph = 5400rpm
my mate put a brick on the accelerator of his old mk2 1043 and left it to see what would happen! 30mins later and it was still going!
Yes it did end up with a holey piston but I think thats is because I had the ignition timing WAY too advanced and nothing to do with the fact I thrashed the shit out of it everywhere :ninja:
^^^^^ did the same on both my gt's and my 1l all ended their lifes through blocked crank case breathers.....
**posted by tain**
Edited by cam
I always thought they were the equivalent of a redline on cars without a tacho? I had't noticed them and had been changing gear a fair bit after them... had a bit of an oops moment when I realised they weer there.
They were on my mk2 which happily revved to around 7000rpm+
1st gear - orange line @ 4500rpm (21mph)
1st gear - 7000rpm (30mph)
I always thought they were the ideal shifting points for quick acceleration and not MPG.
