Longer wheel bolts
I'm after some longer wheel bolts, I fitted the coilies on sunday and if I go so far down the spring and adjustable rings either catch the rim of the tyre!
So my mate is getting me some 10mm Spacers, so can anyone help me with what size I need and where to get them from?
Mk4 6n and I'm currently running standard steels!! (Looks erm. . . . great!)
Nick
  • Replies 13
  • Views 1.6k
10mm will be too much for just using longer wheel bolts
5mm spacers are ok with longer bolts... can get the bolts from grayston engineering (google for website)
Nick
I'm going to use these guys when I need to get my spacers and bolts http://stores.ebay.co.uk/performance-car-shop. the bolts are M12's x 1.5 I think and just measure your current bolts and add 10mm.
Mark
Could you not use Hubcentric spacers with the longer wheels bolts?
I just need to get them away from the coilovers for obvious reason (and it means i can go lower!)
So whats the best in this situation?
Can i get 5mm spacers?!?
Nick
10mm hubcentrics are very rare... only H&R that i know of and they are pricey
most companies start hub-centric at 12-14mm
5mm should be enough to solve suspension problems unless u have a wierd offset wheel or your camber is miles out
Yeah i can get a set of 5mm spacers for £15
So any ideas of where to get the longer bolts?!?
i got some from ABP motorsport in crewe... but also rim style sent me some too
Howe much did they set u back?!?
I converted to studs. £10 for the studs and £16 for decent nuts. As the thread is common to my Manta and the Golf, I can use the same rims on both cars by using the right nuts for each wheel.
Grayston Engineering (google for website)
8-)
Yeah have dropped them an email!
Oh and is 4 5mm spacers for £15 any good?
Very cheap :lol:
Guessing they aren't hubcentric
Dunno, my mate can get them for me as he works at "Camberly Auto Factors"
He is a life saver when you need summin urgently!
