Removing/ Re-fitting Arch trims and bump strips
Have done a search but not come up with much. Trying to figure out to remove the arch trims and bump strips off a Gt and re-fit to my Parade.
Can see the plastic rivet type things holding the arch trims on but how do you release them? Is it just a case of drilling through them and getting new plastic rivets to refit them?
Also the bump strip that goes along the bottom of door sills.. is that just glued in place?
Bump
