Short Shift Kit
Mk3 Polo Short Shif Kit available from
AdvancedAutoSport
phone number 01543683051
other polo stuff available on their site :thumbsup:
Edited by GiorgioGT
  • Replies 18
  • Views 8.2k
there is a short shift kit for a mk3 polo?!
all i thought there was is to cut the gear stick.haha
If anyone can find this thread id like to have a look at the shifter kit!!
hhhhhhhheeeeeeeeeeellllllllllloooooooo!!!! it was me!
web addy: www.advancedautosport.com phone number 01543683051
ring and ask 4 eric...top bloke short shift kits are £220 and it comes with a gearstick as well
Edited by mrgt
Or someone email them and get some pictures?
make your own itll take twenty minutes fabricating a bit of metal to place on the end of the relay shaft to move the position of one of the shift roads and reduce your throw depending on how long the extension is to the relay shaft, by 30-50 percent, i couldnt use the 50 setting on mine as it would foul the engine block
relay shaft
missinglinkz short shift kit
you can just see th eextension in the bottom left of this picture, it has one threaded piece with a nut which fits in the relay shaft where the selector rod would meet, and then you would attach the selector rod in one of the two new holes for 33 and 50 percent throw reduction...
some people claim you can just bend the relay shaft to for a budget quick shift...
anyway i hope teh relay shaft is the same on the polos! otherwise your gonna be bumraped paying 220 quid for the kit
wow that is an expensive short shift kit! esp if that is all you need to do!
grungeisdead if you want to do mine youre definately welcome to!
i am interested in their rol cages though, may be a bit on the pricey side for the full cages though.
Will have to find out exactly what it looks like and check some previous cages.
Bolt in full cage?! whats the point!
http://www.4crawler.com/Diesel/ForSale/
all the details on the above site chap, worth a looksie, cost me 57 quid for my setup for golf, ill have a nosey at the polo to see what the setup looks like on there as I've no idea, hopefully its exactly the same...
the chap on that site is a legend he provides the details to make it yourself cos hes a diamond and also sells kits to lazy people :)
and for a weighted shift rod
This is what it looks like on the polo. I'm finding it hard to see the similarities.
Mark
can you get an exploded picture of other end of the linkage, for the actual gear selectors and not the shift rod? as that diagram you've shown me looks identical to the setup for my gear shift rod on the golf...
the polo mk1-3s share alot of similarities to the mk1 golf, and the mk2/3 golfs have different linkage setupis so i cant imagine vw reinventing the wheel for the polo when they had something that worked well with the golf
cheers max
Cool... :)
This one?
hmm is part 13 a gear selector? ill have a nosey on etka and in the car when i can be arsed and let you he know what i reckon, I've never seen the gear selectors on the olops as I've never stuck my undert car but ill have a gander over the holidays, I'm sure there is a way of pikeying a short shift for these without spending 200 quid, thats bend over and get ready for a raping territory
I'm sure mk3 polo is different to golf ones
but why is this post in polo chat, when it has just a link to a website...
you have been a member for a while and know this isnt how things work, *slap slap*
saf, is that all you need to make it short shift? looks similar to a mk2 setup, would like to give it a try...
No 13 is a breather tube. The gear selector basically attaches to another rod which passes through 14 and 15 on the second picture.
It started out as request to find a missing thread about a short shift and it has now developed into this.. :) but yes it needs to be moved :)
Mark
don't golfs have linkage rods? whereas polos just use one linkage?
The pictures that Grundgeisdead has posted are for the big block Golf. They are completely different to the small block. The small block is very difficult to modify to any form of different throw. The simplest way is to lower the pivot. Unfortunately, it's already level with the bottom of the car and the amount required to make a real difference would have it scraping the road with some of the cars on here. The next best way is to lift the linkage into the car and have it passing through a hole in the exhaust tunnel. The easiest to install is the hardest to make. I've been kicking the idea around for a while as I want to extend the lever around 6" so it's nearer the wheel, but this makes it even harder to come up with something that fits in the existing hole.
This is what AAT will be selling. As you can see it's designed to pass through the floorpan. Dead easy to make a similar system if you don't mind a bit of welding and bodging.
Edited by yeha
Now that is a cool... and a bit scary looking piece of kit!!! :)
interesting, cheers guys just didnt know one way or other, i might consider investing in one of those in the future possibly depending on plans but nice to know whats out there for the polos
