removing back bumper problems!
basicallyy i need to get the bumper off to remove the small tiny dent that drives me mad!
i removed the plastic part but came to the metal bottom section removed all the screws except the two underneath which didnt fit any sockets so would not come undone! anyone whos removed both parts befor i need help!
cheers
Edited by Dom101
  • Views 1k
did you remove the bolts in the middle? (the ones you see when you open the boot) also the arch liner screws need to come out.. well the full thing is in haynes so maybe you missed something?
come on people
Its a two part Bumper, plastic at the top, middle at the bottom
To take pff the main part, get the screws on the top which are accessable once the boot is open, and the scres in the arce lining. then give it a good pull and it should come off ( trick is to open up the bumper around the arches then pull the middle.
Once thats off theres then 3 ( i think) bolts. undo these, and you done!
Fitting is prettey much the reverse
Chris
cheers mate :D
got all the way throguh to removing the metal part but two screws underneath just didnt bodge!
Edited by Dom101
