6n - fogs, loom, swith, grill inserts.
  • Replies 10
  • Views 1.2k
Wonder how much they'll bring.
Wouldnt say that any of it was rare thou??????
as a full set like that it is,,,itll go for quite a lot.
think ill go for around £110 maybe even more
last set like that went for £120.
Lads look again!!!! There for a LHD Polo! The switch is facing the wrong way which means you would need to replace that part... Something to think about anyway...
What you on about? :?
The switch is right way round, they are the pre 98 models which turns the other way... :lol:
Ooops my bad.. shouldnt post when I'm hungover... Heads not workin right apologies
how much would a post 98 switch be? does in not just wire into the fog switch that is already there?
You'll need a fog switch with two pull out bits, one for the front, one for the rear. The normal one only has one click for the rear.
