help bbs 15
just went to northway tryes and my bbs rz dont fit
they are 4 stud 15 inc
they said 2 of the studs are 2 close or sum tin like that on the rim
what does that meen
can i get something to fit it
they said like the rim hole is too close or too small
what should i do
  • Replies 9
  • Views 1.5k
are they 4 x 100?
sounds like u didnt listen to what the fitters were sayin.. if u cant explain what u mean how can we help???
startin with what car they going on.
best give them a ring n find out what they meant.
shouldb a 4x100 with a 57.0 center bore.
what were the wheels advertised as when u bought them? any idea of ET????
Edited by riskie
probably need re-drilling
What car is it?
polo 6n2 2001
thanks for help
THE PCD IS 108, THEY ARE FOUR STUD, OFFSET IS ET37, BACK SPACING IS 114MM, WIDTH IS 7J AND THEY ARE 15" RIMS.
bbs rs without studs
Best of putting them on ebay or something. Or if you were sold them as 4x100 take them back with a can of whoop ass to boast.
No point in getting adapters for them when you can buy them cheap enough in 4x100.
second that I'm affraid.. 106 series2 fitment????
Edited by riskie
where can i get adapters
would i need 108 ones
20mm adapters are £140 roughly.
