Mk3 Gt's
Considering buying a Polo Gt, what i want to know is:
Some history on the engine.
What are the ways on tunning the engine?
What sort of Bhp could i be expecting?
Thanks in advanced,
Scott :-)
History of the engine? Well the 3F lump is closely related to all the other small block VW engines, just with slightly higher compresion than the rest of the UK engines, and a slightly sportier cam profile. The engines themselves are nigh on indestructable, the worst that usually happens is head gasket failure. 75 bhp or thereabouts from new.
A chip, filter and decent exhaust and you won't be far off the 90 bhp that a lot of tuned GTs seem to sit at.
They are a cheap engine to modify to 90-95 bhp, but above that things start getting expensive.
Cams for another 5-10hp, cams are a fairly cheap mod at around £250 with matching tappets and installation.
just go for the basics. Get a chip off poloace on here when he gets back from china, good for 5ish bhp and some torque, a golf gti air flow meter and a performance air filter for another bhp or two, fast road cam as said above good for 5-10bhp. they're pretty good bases to start with. Go for decat and better exhaust afterwards, but then you start to get into more expensive territory.
what they said above ^^^^. If you want more than 90-95bhp, you're looking at head work or bike carbs. Just buy yoofs engine and you're there!
