13's on a 16v mk4?
as above been offerd a set of slot mags, just wondering if they will clear my breaks?
any help will be very helpfull,
cheers Adam
  • Views 944
AFAIK the 16v has 14's as standard because of its bigger brakes, i'm not definite, but i'm pretty sure on this, i'm hopin to get a valver early next year.
correct,,13s wont go over the brakes on a 16v,,I've tried it matey.
Would this apply to a 1.6 Mk4? As mine has 14s as standard.
Some 13s will fit over the brakes but it depends on the wheels themselves. As a rule of thumb (to be safe) assume 13s won't fit.
As for a 1.6 8V I can't really say. If it has 239mm discs ( which I would imagine it does) then you should be able to put 13s on it. But if it has bigger brake sthen you will need bigger wheels.
Personally I think 13s are far to small for a 6N unless you have it dragging on the floor to achieve the correct stance. Like that matte black one.
