scratching sound from my steering wheel
need some advice, every time i turn my steering wheel it mkes a horrible scratching sound, from behind it. any ideas some one must hve had this problem, its only just started happening! n i hve a airbag in the wheel, if i need to take the wheel off how do i get the airbag off too?
thanking you ;)
  • Replies 9
  • Views 1.5k
i think its just some grit that has managed to get in there, think loads of people have had this problem including myself, best solution would be just to spray some WD 40 behind the wheel
abit messy but ill give it ago!!!!!!
The horn connection must have dirt behind it, same thing happened to mine. I used a fine flat headed screw driver to scrape the sh**t away( jobs a good one) :thumbsup: .
I had this a few weeks back, really loud with it too. Then it just stopped and hasn't come back since :thumbsup:
Agreed it is the horn ring connector. I used a cotton bud with the head squashed with a pair of pliers dipped in 70%(medical) alcohol to get all the crap out and clean the ring. Then a quick wipe with a WD40 soaked cotton bud.
Sweet as.
PoloD.
I've been getting this loud scratching noise to and now my horn has stopped working, linked??
yup.
see above. nothin serious!
so is it just a case of grit in there? clean it and all should be ok? i didnt wanna go poking about in there incase it was sumit to do wi the air bag lol
i have the same problem, ill give it a clean! let us know how yr clean goes!
