replacement rear arches for a mk3 coupe
Basically, both my rear arches have rotted away under the plastic arches! Already replaced front wings as well!! I need to get hold of a supplier of replacement ones, anyone know??
Any help is much appreciated.
Andy
  • Views 1k
just cut the arches of a polo in breakers yard and step the panel and weld in, finish with small skim of filler, loads cheaper and easier than using cheap ill fitting aftermarket panels,
