Mk3 Door handle
When i went to open drivers door car a few months back the plastic housing of the handle would just move and the lever wouldnt open the door,
now i can't get in on the drivers side alltogether, will i be needing a new lock mechanism and barrell (assuming a new key too?) or is it that there is a lever/ that has simply snapped?
Edited by martinb
  • Replies 8
  • Views 2.3k
I have a full set of locks with key that i can remove from the car for you if you want.
Cheers mate, will bear that in mind if it turns out i need to change the lot.
how easy is it to remove the locks on a mk3?
how much you after delivered?
It's dead easy to take the handle off and then you should be able to see better what's damaged/wrong. Prise off the plastic/metal trim going across it to reveal one screw, and the other is on the inside of the door (assuming you can get it open at all lol)
I haven't looked in any more detail so I don't know if the locks can be separated from the handles or not :?
Probably need a new handle at worst case. The original lock barrel can be removed from the damaged handle easily by inserting the key, removing the crosshead screw on the other end of the barrel, then removing the casting and spring(noting how they fit) and draw out the barrel.
Repeat the process to fit it to the new handle.
Just to say that I replaced a handle yesterday on my GT. You don't need the key for the lock barrel on the replacement handle, just put your key in and do what 86C says above and then it'll all come apart. Its then dead easy to swap the lock barrel from your broken handle into it. Took me about 15 minutes to do the whole job, including cleaning the mechanism on the handle up :)
I took the handle off tonight, loks like something has cleanly snapped off and not allowing me to open the door:
What would i need from the scrapyard to fix? i haven't a clue about handles and locks!
Just get another handle complete and swap the lock barrel over as described above.
thanks for the help Steve, all in all it was a quick job... handle from a mk2 golf did the trick :)
